'71 Deluxe
Postby Franz » Mon Aug 08, 2011 7:11 am
nice!
Postby cookiemonster131 » Mon Aug 08, 2011 7:52 am
Congrats! So what was the problem with it from June 8th?
ramzrod
Postby ramzrod » Tue Aug 09, 2011 7:31 am
Schmitty wrote:http://www.youtube.com/watch?v=jnVnKZeKNAY
Congrats bro! That is the best feeling and the best memory you will ever have! Cool you got it on video. I still remember my first drive in my VW and I wish I had it on video. You look stoked and that will drive you to finish it! =D> =D> =D>
Ramsey
|o\®/o|
#377
Schmitty
Postby Schmitty » Thu Aug 11, 2011 11:08 am
No doubt, the wiring looked like a really simple puzzle after that first drive. In fact, I bravely just disconnected my whole ignition and turn signal assembly so I can take out the lock cylinder. Not too easy Smile
Turns out the Transaxle was fine. The clutch disk was too small, and the pressure plate had that (I'm sorry, I have no idea what its called) spacer-ring on the inside. It put everything in a bind, sheared off some stuff, but its all good now. Clutch disk is still good(Just not on my bus), and I ended up using that same pressure plate.
The major problem was a lack of motivation seeing a baywindow sitting NEXT to the garage(Dad won't pull his Chevelle out for anything... Even though I'm in his spot now Smile )
In the video, that's the same engine, but with 1600 pistons and cylinders. The 1500 rings were absolutely fried. I took the cylinders off to inspect them and on #3 they were totally sucked up against the piston, serving absolutely no purpose. On 4, I grabbed the oil ring and it snapped in my hand. Grabbed some pliers to unstick the other rings and another one snapped off. So I got some donor pistons and cylinders from a spare engine(Thanks Chris) that the rings were fine in, honed out the cylinders, and viola! I also figured out that a wide hoseclamp works perfectly for getting the rings in the cylinders! Figured that one out all on my own ;)
I'm currently trying to scrounge up money for a linkpin beam so I can drop this thing. I get a nosebleed just looking at the thing.
Current goal is BNNTA! Anyone else going?
Oh, I forgot to mention, I have a letter sitting in IDoT requesting a bonded title. I'll keep you all updated on that, too!
Jake
