New Project - 68 Double Cab
56Hotrod
Postby 56Hotrod » Tue Apr 24, 2012 2:32 pm
Beetjunky wrote:So what was the problem with running 15s in the back and 14s on the front? I am doing that right now. Not really but choice but was thinking about keeping it.
Nothing other than having different style wheels. Hard to notice though, as it took me until I was getting ready for tires to know I had 3 different style wheels on the truck Smile
56 Oval Project
68 Bay DC Project
2012 Paxton Supercharged Mustang
http://www.steven-laura.net/Steven/
Beetjunky
Postby Beetjunky » Tue Apr 24, 2012 2:51 pm
Mine had 14's on it when i got it and i have the wheels powder coated and bought tires before i even had an engine for it. Now i have an engine i can see the 14's are driving my RPMs through the roof. I am rolling now with my bug wheels and tires on the back and the 14's still on the front. It would kill me to buy all new rims and tires....lesson learned.
56Hotrod
Postby 56Hotrod » Wed May 23, 2012 8:54 pm
Picked up the truck from Pops this weekend, and got her nestled back into the garage :)
Finalizing some of the motor build. Got the full flow setup done, then I decided not to take a chance with the old doghouse cooler and bought a new one. Flywheel is torqued, chromoly push rods are cut and ends installed. I started making a pre-oiler out of PVC tonight but need one more fitting to get that done.
She's getting close...very exciting :)
56 Oval Project
68 Bay DC Project
joezeeuw
Postby joezeeuw » Thu May 24, 2012 9:30 am
Paint looks very nice. Looking forward to seeing the icing.
Postby DaKine » Thu May 24, 2012 11:17 am
love it dude, that paint looks bad ass! =D>
56Hotrod
Postby 56Hotrod » Sun Jun 24, 2012 11:13 am
Lots of progress. Engine is ready to go into a test stand that I built using $12.30 of scrap angle (1.5" and 3/16" thick). I have the tranny already bolted to the rear half of the stand.
Took some pics of the truck with the kids as well.
56 Oval Project
68 Bay DC Project
Postby tlambert » Sun Jun 24, 2012 11:30 am
Nice, looking good.
Postby scottsain » Sun Jun 24, 2012 1:38 pm
please tell me that will be at drag night!
Postby Franz » Sun Jun 24, 2012 2:22 pm
Bitchin' camaro!
56Hotrod
Postby 56Hotrod » Thu Jun 28, 2012 12:10 pm
I'd love to make it down to drag night, but this won't be ready. Now, if they'd let me run my 11 sec Evo, that would be peachy :D
56 Oval Project
68 Bay DC Project
Postby tlambert » Thu Jun 28, 2012 9:04 pm
You gotta make with or without the DC. Just get there.
wornRAGS
Postby wornRAGS » Mon Jul 16, 2012 7:06 am
That double is totally bitchin!!!
misunderstood....and I like it that way.
56Hotrod
Postby 56Hotrod » Tue Jul 17, 2012 4:36 pm
Making lots of progress (for the 1-2 hours I get in the garage at night after the kids go to bed).
Engine installed in test stand and wired up. At first, she would barely turn over, so I bought a new battery. Still barely turning over, and I got a cheap china starter from Advance (and it smoked in 5 minutes). I put the old starter back in, took out the plugs, and she turned over beautifully. So, I sleep on it. Then it came to me in a vision, and I felt incredibly stupid. I had double/triple checked the distributor drive gear upon putting the motor together, but I second guessed myself a month later when everything was together. Pulley at TDC and the rotor was pointing to number 3...so I thought, well, maybe I installed it 180 off. So I wired it making that assumption (#1 cylinder where #3 would normally fire). The vision reminded me that the cam turns at 1/2 the engine speed and thus TDC is also the TDC of the exhaust stroke on #1. I was like, DAMN IT, rookie mistake.
Went out the next morning, wired it up normal, and what would you know, fired on the first revolution. I still have have to break it in, and adjust the carbs, but she idles marvelously.
Only issue I have, is the POS EMPI remote filter housing. The IN and OUT ports leaked pretty bad, so I tightened them, and they still leak. I took it off, cleaned it, and put a good bead of permetex on the threads, and let it sit for 24 hours...still leaking. These are with aluminum fittings, and I think they are just not soft enough to get a good seal, so today, I ordered some brass ones. If that fails, I guess I will look at a different filter housing.
Also, I got all the wiring accounted for and checked out. What a mess to figure out who knows how many previous owners have wired up stuff...but after a week, all is accounted for, AND all wiring is color coded correctly too.
Going to clean up/ tiddy the wiring, tonight. Also need to install the shifter rod and shifter...do a little POR15 in the rear and the motor will be ready to go in.
GETTING CLOSE!
http://www.steven-laura.net/Steven/68DC/firststart.mp4
56 Oval Project
68 Bay DC Project
joezeeuw
Postby joezeeuw » Wed Jul 18, 2012 3:47 am
Sounds mean! way to go.
I like your welding cart. Hope the kids don't mind Smile
56Hotrod
Postby 56Hotrod » Wed Jul 18, 2012 5:04 am
Thanks
Yeah, Nathan has complained about his Radio Flyer for about 3 years now.
56 Oval Project
68 Bay DC Project
