Russ' 65
Air Kooled Junk
Re: Russ' 65
Postby Air Kooled Junk » Sat Apr 30, 2016 6:04 pm
Looks great,I can't figure out what lug pattern you have!
type4revolution
Re: Russ' 65
Postby type4revolution » Sat Apr 30, 2016 6:13 pm
Looks like 5x130 don't think those wheels come in a ford pattern.
Re: Russ' 65
Postby russ scott » Sat Apr 30, 2016 7:24 pm
type4revolution wrote:Looks like 5x130 don't think those wheels come in a ford pattern.
correct
944 spare wheels (extra holes added)
finally set my ride height i'm happy with, i'm sure once i drive it for a bit it will settle and i'll readjust it a bit
Re: Russ' 65
Postby russ scott » Thu Jun 02, 2016 10:07 am
changed a few things on my car, I had a faucet fuel pump and it sounded like a damn machine gun.
swapped it to a carter pump and added a fuel shut off switch so I don't have to drain the tank again
I had a little dial regulator and everyone said they fail and suck so swapped it out as well
I welded a fitting on the breather I have for a draft tube as well
now I just need decent weather to drive it for a bit
Re: Russ' 65
Postby K Leake » Thu Jun 02, 2016 10:19 am
Nice and clean =D> =D> =D>
