Time to FK up this here bus...
dcguy
Re: Time to FK up this here bus...
Postby dcguy » Tue Nov 15, 2016 11:50 pm
Long time! I did start to won on her again!
Some of the OG paint roof exposed..
Nobody wants her, so I gotta get to work!
And this is the reason I decided to keep her..
Pop...
and..
dcguy
Postby dcguy » Tue Nov 15, 2016 11:52 pm
dcguy
Postby dcguy » Tue Nov 15, 2016 11:53 pm
I'm not very good at the filler/sanding/priming thing. But I have some practice and I can't gaurentee it will be straight, but it will be better and less rusty than before (plus it will be running/driving!).
(Also I am open to suggestions, like should I put filler on the whole long side thin coat and sand it down or just do the little bit that I have?)
Postby john jones » Wed Nov 16, 2016 5:48 am
depends on how nice you want it... it could get better if you spread the whole side... but.. your saying your not too good at it.. it might get worse? :-# :-# :-# :-# :-# :-# :-# One thing is for use.... Spreading and sanding a whole long side sucks balls.... be carefull... :-$ :-$ :-$ :-$
Postby rustabus » Wed Nov 16, 2016 5:50 am
Pretty sure John gets it as straight as possible then runs a super thin coat across the whole long side then gets a big ol long block and sands 98% of it back off again!!! :-k :-k Wink Smile
Well, guess John is posting up same time I am! Smile
dcguy
Postby dcguy » Thu Nov 17, 2016 2:30 pm
I'm going to leave it 'as is', fix the rust and get it as straight as possible with as little filler and see how it turns out. I was going to repaint the whole bus, but I kinda like how it looks now. Just going to paint the exposed bits and get it driving.
Postby George » Thu Nov 17, 2016 2:37 pm
dcguy wrote:I'm going to leave it 'as is', fix the rust and get it as straight as possible with as little filler and see how it turns out. I was going to repaint the whole bus, but I kinda like how it looks now. Just going to paint the exposed bits and get it driving.
Sounds like a solid plan =D>
dcguy
Postby dcguy » Thu Nov 17, 2016 6:21 pm
More sanding! Looks worse, but IRL looks pretty neato...
dcguy
Postby dcguy » Mon Nov 28, 2016 9:27 pm
Trying to get to the OG paint is pretty hard. The filler is not fun to get off :)
Postby Franz » Tue Nov 29, 2016 8:25 am
Pictures died.
Hows it going JP? That is a serious bus. Are you going to keep it long enough to enjoy?
dcguy
Postby dcguy » Tue Nov 29, 2016 3:59 pm
I will fix the pics thanks Franz. Yeah, getting old now, I've decided to keep the 15 Window and the Porsches. The rest I am going to sell and if I get lucky again, the only other bus I want is a barndoor. It takes too much effort to fix a bus then turn around and sell it, and in the summer, guess what? NO BUS. Sucks. Not on that train anymore. If I touch it, I'm keeping it.
Postby rustabus » Tue Nov 29, 2016 7:00 pm
Good Plan!!! =D> =D> =D> =D> =D>
Postby PeteSC » Tue Nov 29, 2016 7:08 pm
If there's ever abus to keep a pressed bumper 15w is gotta be high on the list. =D> Keep chipping away at it!
Porsches? :-k
dcguy
Postby dcguy » Wed Nov 30, 2016 1:33 am
I got lucky and sold a few buses and bought some a 911's, they're fun to drive, and complete, no work needed, big change from the buses.
This is supposedly a 1 of 25 bus, more rare than any 23 Window/BD, so it's not going anywhere :) KCW has worked on a million rare buses but I don't think they have done up a pressed bumper 15 Window (so here I am repping!). Of course I'm probably wrong a million times over (I usually am). 8-[ =D> =P~
dcguy
Postby dcguy » Mon Apr 24, 2017 5:21 pm
Cleaned the shop floor a bit and put some epoxy on it. It floods out during the spring thaw so I had to do a bit of something. Plan to build a french trench so it doesn't happen anymore. And got the 15 winder turned to do the passenger side!
