Dogo's '57 rag
Postby DOGO » Thu Jan 20, 2011 11:28 am
Got it. Melted wires would be bad. Thank you.... But THIS, below, could be worse!!
I had the car runninig this morning while checking the lights. Maybe 20-30 minutes. I Didn't notice anything. I while later as I'm stepping out I walk by the car and see THIS!
It's coming out the breather tube. I start it up again and no leaks (other than a couple of drops that were probably still in there)
What could it be/have been??. Please don't say rings!! [-o< ](*,)
hitlersride
Postby hitlersride » Thu Jan 20, 2011 1:10 pm
GAH! I feel for you man. If you need any 36hp stuff lemme know i have a few things hanging around.
Postby DOGO » Thu Jan 20, 2011 8:10 pm
DOGO wrote:Got it. Melted wires would be bad. Thank you.
I just re-read this… Did that sound really asshole-lishly sarcastic? :-k I see how it might’ve. Sorry about that, it wasn’t meant to. I meant thank you for reaffirming that a fuse would be a good thing
Postby DOGO » Thu Jan 20, 2011 8:11 pm
hitlersride wrote:GAH! I feel for you man. If you need any 36hp stuff lemme know i have a few things hanging around.
Thanks, man. Really appreciate it. Hopefully I won't need anything, but will keep it in mind.
Postby DOGO » Sat May 28, 2011 1:55 pm
Finally made time to get around to this (the oil busting out of the breather tube). Oil level was high, which wasn't before. I could smell a little gas in the oil. So I decided to rebuild the fuel pump and put a gauge in it to see the pressure and it's a hair over 3psi. Question is: is it acceptable pressure? I remember reading it should be at about 2.6 (?) (stock 36er) and about shiming the pump to reduce pressure, is there an actual shim meant for this or just an extra gasket/s will do? I have a couple of gaskets. How much pressure does each gasket reduce, aprox? Where is it convenient that I ad the extra shim/gasket, between flange and case, or flange and pump?
Thanks!
Boom
Postby Boom » Sat May 28, 2011 1:58 pm
I dont think I would worry about a the small amount of extra pressure.
but if you had fuel in the oil that would make it come out in places it normally wouldnt as it thins the oil
Ovals are Overrated....
Düg Büg
Postby DOGO » Sat May 28, 2011 2:13 pm
I'm not sure what the pressure was before rebuilding. Mightve been even more, who knows.
Do you -or anyone- know the operating pressure? I know 1/2 psi doesn't sound like much, but in the bigger picture IF the operating pressure IS in fact 2.6, 1/2 a psi is almost a 20% increase, it must have some effect, I'd imagine?
Postby DOGO » Sat May 28, 2011 9:04 pm
Well, I went ahead...
After 3 (maybe 4) tries, combining different gaskets...it's done, and pretty much right on. It's amazing how much of a difference the slightest difference in thickness from one type of gasket to another makes
Postby frvngn » Sat Aug 27, 2011 6:21 pm
This one's for you DOGO......perfect stance....
Good to see you again!
Tuned Perfection
Postby Tuned Perfection » Sat Aug 27, 2011 7:00 pm
That car is so badass!!! Perfect stance, color, rims and tires.... sweet car!
Stay on the porch.
Postby gonebuggy » Sun Aug 28, 2011 7:46 am
Good to meet you Pablo, and Greg is right! LOVE your car.
Postby DOGO » Mon Aug 29, 2011 9:05 am
Thanks, guys. Thanks for posting the pics.
What happened to Ron's pic :-k . Or is it just me that can't see it.
Anyway, thanks, it was a good time!
slammed and shiny
Postby slammed and shiny » Mon Aug 29, 2011 9:13 am
i cant see it anymore either.
hitlersride
Postby hitlersride » Mon Aug 29, 2011 10:50 am
so I take it your drive home was as enjoyable and worry free as mine....yaaaa!!! \:D/
Postby frvngn » Mon Aug 29, 2011 3:46 pm
fixed.......I moved the pics to a different album and forgot to re-post.... #-o
sorry about that.... #-o
http://s224.photobucket.com/albums/dd26 ... BQ%202011/
Users browsing this forum: Google [Bot], vfrguy and 1 guest
