Dans Boosted Oval Rag
Re: Dans Boosted Oval Rag
Postby 68tintop » Fri Apr 14, 2017 11:13 am
Wozer bro that shut looks gooooood. I wish it wasn't the wife's bday. I would cruise down for first drive that's going to be sweet. Wicked cool car. =P~ \:D/ =D> :-#
Postby Franz » Fri Apr 14, 2017 12:36 pm
First drive. Not running correctly. Maybe dirty injectors or something. I should probably hook it up to a computer to do some diagnostic. The other thing that I'm thinking is the fuel pressure regulator does not have a vacuum line to intake manifold pressure. I was under the assumption that this system does not need that? It'll be easy enough for me to run a hose and test.
Everything else is great.
Postby PeteSC » Fri Apr 14, 2017 2:00 pm
THAT is one gorgeous car. Nice job to all of you guys involved!
Postby Franz » Fri Apr 14, 2017 3:30 pm
I feel a little early posting completed pictures of the finished car. Once the running board trim, and interior is installed it will look much different. Doug will do that shortly I am sure (he had his kids on spring break all week).
I need to get the tuner software so that I can diagnose and change things. I sent an email to cb performance.
Postby andym » Fri Apr 14, 2017 4:40 pm
What's it doing?
crap out on top end? Check the gap between the crank trigger and the tooth wheel on the Pully.
Spark and fuel, those you Shouldn't have to adjust much if any.. They work or don't.
All set ups I've done use a fuel pressure vacuum regulator, besides the one on my squareback. It's self regulated at 58 psi.
I think there was a vacumm line that hooked up to the cb box under the rear seat.
Postby scottsain » Sat Apr 15, 2017 5:46 am
andym wrote:I think there was a vacumm line that hooked up to the cb box under the rear seat.
Mine has one like that.
Postby Franz » Sat Apr 15, 2017 7:09 am
Super rich. I remember it being that way when we fired it up before taking it all apart.
I have a vacuum line to the ecu, and fuel pressure regulator. Fuel pressure is set at 45 psi at idle.
Mark lawless from CB is going to sync up to our computer next week to tune/see what's going on with this.
Postby john jones » Sat Apr 15, 2017 7:31 am
I know it wasn't running great yet.. But it put a big smile on my face to see it roll down the road under it's own power!!!!!! and Dan.... NO ONE is ever going to miss your brake lights!!!!!!! \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/ \:D/
That turbo has such a unique and awesome sound to it... =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
Postby andym » Sat Apr 15, 2017 8:25 am
Yeah I remember that Franz. It might need the o2 sensor just calibrated. Wideband calibration. Once it's calibrated, then it will know the air fuel ratio. If it's not calibrated then typically they load up.
Postby Franz » Sat Apr 15, 2017 9:02 am
That maybe it. :-k I remember the a/f ratio was reading 13.5ish while it was blowing black smoke.
Postby scottsain » Sat Apr 15, 2017 12:44 pm
Franz wrote:Super rich. I remember it being that way when we fired it up before taking it all apart.
There you go.
silas
Postby silas » Sat Apr 15, 2017 11:57 pm
Franz wrote:Image
looking good!
Zündfolge Car Club
Stock Motor Challenge
Postby JWDII » Mon Apr 17, 2017 5:01 am
Beautiful. Looks stunning in the sun! =D>
Postby Franz » Mon Apr 17, 2017 7:08 am
Doug was here this weekend. Sound deadened and carpet installed.
Postby tlambert » Mon Apr 17, 2017 9:44 am
Red looks really good. =D>
Users browsing this forum: No registered users and 6 guests
