Parkway Projects "fix Everything"!!!
AKA The Thursday Club.
Re: Parkway Projects "fix Everything"!!!
Postby andym » Mon Jan 02, 2017 7:59 pm
Awesome!!!
Postby Franz » Tue Jan 03, 2017 8:53 am
Swapping engines is pretty easy. :-k The naked stroker is turn-key ready for a trip?
Postby BBWB » Tue Jan 03, 2017 8:57 am
I'd say it's ready Franz. I'd trash those heat exchangers, they're shit aftermarket.
Notchyours
Postby Notchyours » Tue Jan 03, 2017 1:32 pm
If you have the time and the want to, then go ahead and put the stroker in. I was hanging back in case JJ needed it or I figured out a different exhaust.
Franz wrote:
I like seeing our customers cars get beat-up. Rock chips and scratches are cool.
Postby PeteSC » Tue Jan 03, 2017 1:50 pm
Any plans for the 1915 coming out of the bus?
Notchyours
Postby Notchyours » Tue Jan 03, 2017 2:28 pm
PeteSC wrote:Any plans for the 1915 coming out of the bus?
the 1915 is going in the bay I picked up front Pat Kendal.
mraible
Postby mraible » Thu Jan 26, 2017 11:21 am
Howdy fellas. Do you guys recommend a clear coat bra (e.g. 3M) on the front of my bus. The folks that painted it said I should get one.
Franz wrote:The good thing about static suspension is that your car looks good all the time. Not just when its parked. Remember that. Wink
Postby jb » Thu Jan 26, 2017 12:31 pm
mraible wrote:Howdy fellas. Do you guys recommend a clear coat bra (e.g. 3M) on the front of my bus. The folks that painted it said I should get one.
Bras are for titties, does your bus have titties? [-(
Postby tlambert » Thu Jan 26, 2017 12:36 pm
Isn't that what those 2 round things are on the front? \:D/
Postby john jones » Sat Jan 28, 2017 4:48 pm
bubba has turned into a parkway project again...
Houston... the frame is missing????????? :-k :-k :-k :-k :-k :-k
Postby PeteSC » Sat Jan 28, 2017 5:15 pm
^I guess that's one way to align the rear...
Smile
volksaddict
Postby volksaddict » Sat Jan 28, 2017 6:12 pm
Thanks for doing that right =D> =D> =D> Bubbas got a cradle w frame horns down here if he needs it.
Postby john jones » Sun Jan 29, 2017 9:01 am
we are wondering what axles are in this bus?? it has a split housing.. with bay stuff :-k :-k :-k :-k :-k :-k :-k :-k :-k :-k :-k
Postby BBWB » Sun Jan 29, 2017 9:07 am
Probably like my set up. My split trans has Thing flanges, just like type II. The first set I had was type II bolt pattern welded to type I flange.
Postby Franz » Mon Jan 30, 2017 8:43 am
Getting ready to weld the rear frame section into the body
Then I can attach to the original frame with 3" x 1.5" box tube. Baywindow c-notch style.
Return to “KCW current projects”
