Subaru fastback!!!!
Subaru fastback!!!!
Postby andym » Sun Feb 19, 2017 3:54 pm
Subaru take over here!!!!
I didn't do this swap, making some changes for the owner. Custom intake to fit under the deck, new coolant lines. Fucking car is awesome it's nice!!!
The owner posts up on here every now and then, let's see if he sees this!
Either way I know JJ loves seeing Subaru on his forums!! :-# :-# \:D/ \:D/ :^o :^o
"23 year olds don't know dick!!!" John Jones
Re: Subaru fastback!!!!
Postby tlambert » Sun Feb 19, 2017 6:54 pm
CLean and simple.
I bet it's fun to drive.
Postby Franz » Sun Feb 19, 2017 7:11 pm
Type 3 auto with subie power?? That could be sweet.
Postby andym » Mon Feb 20, 2017 8:31 am
The Kennedy adapter is only for a manual trans as far as I know. But one with some time and energy could figure that out I'm sure
Postby BBWB » Mon Feb 20, 2017 8:46 am
^^^I think a Subaru flex plate re-drilled for the VW converter would be super simple.
Postby Critter1 » Mon Feb 20, 2017 11:08 am
I like the use of the factory dip stick. =D>
Postby 63single » Mon Feb 20, 2017 11:51 pm
Me too Justin, i can yhink of at least 3 cars that are gonna get that same treatment....
volksaddict
Postby volksaddict » Tue Feb 21, 2017 6:38 am
What IS the factory (vw) dipstick used for now? :-k
Postby andym » Tue Feb 21, 2017 6:45 am
Nothing, it's cut off. I need to find a replacement. Its cut and put it back in to fill the hole.
Postby andym » Thu Feb 23, 2017 8:54 am
Got the stock intake off. Chop chop!!!
Also switching over to microsquirt for the engine management. Almost a full build now!! Atleast I know it runs and drives.
Sunday couple of them are leaving my place, couple are coming in..
Postby andym » Mon Feb 27, 2017 11:59 pm
Ive been balls deep in the fastback, intake off and cut down, then took it to my mill to get it flat. Traced the intake ports on a piece of aluminum, hole saw then alumin burr. Fit over the intake stack, then weld on the inside. No outside welding around the stack, that's a bitch! I'll cut a piece of 2 3/4" round, so it's a "n" shape and weld the bottom to the flat. You'll see..
Oh yeah, another one showed up for wiring and exhaust. Split bus!
Postby tlambert » Tue Feb 28, 2017 6:57 am
Kicking ass Andy. Man how many are out there subi powered!
Postby BBWB » Tue Feb 28, 2017 8:31 am
^^^^Just looking at You-Tube, I seen over twenty conversions in splitty's alone. No telling on bay's, vanagons, type I, and III's.
Postby Bret » Tue Feb 28, 2017 9:45 am
andym wrote:Image
Hey! Would you look at that! Wink
Way simpler than the original idea!
Postby JWDII » Tue Feb 28, 2017 10:30 am
I look at this pic and keep hearing , Welcome to The Swap House!
Looks like you have figured out how to make Water Cool in some old VW's.
Users browsing this forum: Baidu [Spider] and 6 guests
