5/66 Double cab
Re: 5/66 Double cab
Postby Glenn A » Fri Nov 04, 2016 12:19 pm
Apparently Photobucket is down ](*,) ](*,) #-o #-o they suck. I had to host some pics on TS to get them up here.
Re: 5/66 Double cab
Postby K Leake » Fri Nov 04, 2016 12:23 pm
Your Double cab is looking great O:)
Re: 5/66 Double cab
Postby john jones » Sat Nov 05, 2016 5:31 am
your killing dude!!!!! =D> =D> =D> =D> =D> =D> =D> =D>
Re: 5/66 Double cab
Postby Glenn A » Wed Nov 09, 2016 9:13 pm
I was originally just going to replace the rear section of floor in this pig so I could put the tank back in. I decided to change the whole floor. I had already cut the floors in half so you'll see they are on four pieces. ](*,) ](*,)
Re: 5/66 Double cab
Postby vwfool » Thu Nov 10, 2016 7:20 am
Going to look great
Re: 5/66 Double cab
Postby K Leake » Thu Nov 10, 2016 7:38 am
Very nice =D> =D> =D> =D> =D>
Re: 5/66 Double cab
Postby Glenn A » Thu Nov 10, 2016 10:53 am
Thanks.
Re: 5/66 Double cab
Postby Glenn A » Sun Nov 13, 2016 5:46 pm
I got the last section of floor out today. I also trimmed back both rockers and the rearmost cab pilar on the driverside. Removed the front top hat and chassis crossbrace. Found that the driver side rail had a little more rot than I originally thought ](*,) ](*,)
going to have to spend some time on that now. Then the drivers outrigger crossbrace and top hat can get fitted next.
Re: 5/66 Double cab
Postby Glenn A » Tue Nov 15, 2016 4:37 pm
Tonight was moving night. There is no way I'll be able to fix this chassis on the ground. So I had to scoot it over to the bay with the lift. Nothing runs ](*,) ](*,) ](*,) Beetle has a clogged fuel line.
Re: 5/66 Double cab
Postby Franz » Wed Nov 16, 2016 7:54 am
Full-on restoration going here. Smile
Re: 5/66 Double cab
Postby Glenn A » Wed Nov 16, 2016 11:43 am
Franz wrote:Full-on restoration going here. Smile
Unfortunately =;
I think this rig would be a perfect spot for a set of triple gear reduction boxes! [-o< [-o<
Re: 5/66 Double cab
Postby Glenn A » Sun Nov 27, 2016 8:43 pm
Waiting on the parts for the frame rail. Floors are mostly fitted. Just have to double check that and then mark and drill for welding. Got the rear middle pilar in tonight and the inner rocker welded in. Also fitted the outer rockers.
Re: 5/66 Double cab
Postby George » Sun Nov 27, 2016 9:14 pm
Looking good it looks like your making good time.
Re: 5/66 Double cab
Postby john jones » Mon Nov 28, 2016 7:03 am
Your work is super clean!!! =D> =D> =D> =D>
Re: 5/66 Double cab
Postby Glenn A » Mon Nov 28, 2016 8:35 pm
john jones wrote:Your work is super clean!!! =D> =D> =D> =D>
Thanks!
The rearmost cab pilar is a bit of a pain on the DC. The Klassicfab's part is missing a small piece that gets spot welded to the side. The Autocraft part comes with it attached. However to my knowledge Autocraft doesn't sell the inner part of the pilar. Gerson sells them as a set inner and outer.
Added that piece tonight and got the inner pilar installed.
