55 Single cab
Re: 55 Single cab
Postby 63Ragtop » Mon Nov 28, 2016 9:35 pm
Epic!
Re: 55 Single cab
Postby vwfool » Mon Nov 28, 2016 11:53 pm
Wow. That's intimidating seeing the whole face cut off like that. well done putting it back together =D>
Re: 55 Single cab
Postby JWDII » Tue Nov 29, 2016 6:22 am
DAMN NUTS! you putting work, after work! Is your name LooseNuts Jones?? :-k :-k :-k
Re: 55 Single cab
Postby john jones » Tue Nov 29, 2016 9:33 am
You got mad skills LN.... =D> =D> =D> =D> =D> =D>
LooseNuts
Re: 55 Single cab
Postby LooseNuts » Tue Nov 29, 2016 7:16 pm
john jones wrote:You got mad skills LN.... =D> =D> =D> =D> =D> =D>
thanks a lot John. means a lot considering coming from you. \:D/
JWDII wrote:DAMN NUTS! you putting work, after work! Is your name LooseNuts Jones?? :-k :-k :-k
shit ton of work too building this
thanks everyone. \:D/ \:D/
IG - @vwloosenuts
www.vwloosenuts.com
LooseNuts
Re: 55 Single cab
Postby LooseNuts » Wed Dec 28, 2016 12:27 am
Worked on the single cab today. Removed the 1960 fresh air box and replaced it with a correct fresh air box.
IG - @vwloosenuts
www.vwloosenuts.com
Re: 55 Single cab
Postby way2cool » Wed Dec 28, 2016 2:33 am
Noice !!!!
Re: 55 Single cab
Postby JWDII » Wed Dec 28, 2016 5:41 am
Good work nuts! =D> =D> =D>
Re: 55 Single cab
Postby Franz » Wed Dec 28, 2016 8:25 am
The difference is the flush edge around the screens and slightly different ribs?
Re: 55 Single cab
Postby jb » Wed Dec 28, 2016 10:23 am
I don't remember when the no lip screen ended, pretty sure early 56? WB buses have 5 position fresh air knob too
LooseNuts
Re: 55 Single cab
Postby LooseNuts » Wed Dec 28, 2016 10:07 pm
jb wrote:I don't remember when the no lip screen ended, pretty sure early 56? WB buses have 5 position fresh air knob too
Franz wrote:The difference is the flush edge around the screens and slightly different ribs?
I don't know when the lip came into play. This one has the lip and wrong screen
Before I actually installed it. I removed the lip around the screen. And added the correct screen and the dimple between the vents so it is correct for 55
IG - @vwloosenuts
www.vwloosenuts.com
LooseNuts
Re: 55 Single cab
Postby LooseNuts » Wed Dec 28, 2016 10:11 pm
Removed the lip around the vents. Installed the correct mesh and added the dimple between the vents
IG - @vwloosenuts
www.vwloosenuts.com
Re: 55 Single cab
Postby 63single » Thu Dec 29, 2016 9:17 pm
Looks great man, when is this thing gonna hit the streets?
squareonair
Re: 55 Single cab
Postby squareonair » Thu Dec 29, 2016 10:01 pm
i believe all 20-xxxxx wolfsburg busses had the flat over hang lip and the larger screen....my 55 singlecab has flat lip round trans cradle but my first of march of 56 kombi has the round tube trans but has the lip on the top...my later march 56 singlecab has the square trans cradle...the 5 dots on the vent i know was thru 57-58 sometime...
patrick
LooseNuts
Re: 55 Single cab
Postby LooseNuts » Thu Dec 29, 2016 10:45 pm
Did some more work on the Single Cab. Welded in the front center cross member. Do some rust repair in the wheel well passenger side. And mocked up the dogleg to test fitment. Also finished welding in the cargo floor.
I order up someon Klassicfab awesomeness.
IG - @vwloosenuts
www.vwloosenuts.com
