The Looser STRIKES BACK!
fidysea
Re: The Looser STRIKES BACK!
Postby fidysea » Thu Sep 03, 2015 7:11 am
Pat K wrote:Found one. JJ says he has you covered. Just post (might receive a few unexpected packages.. [-o< ) or PM your address... Smile
Awesome!
Thanks KCW crew!!
I really needed some good news. We were headed to school today and the Datsun decided not to shift. I was a stop sign at the end of the street. It would not go into 1st or 2nd. ](*,) It started getting tight driving home from soccer last night. :-k It would grind into reverse so I backed up the street and back into the driveway.
We jumped on the bike.
I am excited to get a spring plate and start on the bus but I need daily TRANSPORTAION.
I might have to bail on this truck.
Looser
2117 Westover Dr.
Danville VA 245451
Wren
Hey, KEEVIIN!!!
Postby Wren » Tue Sep 08, 2015 6:36 am
Good looking Bus! Good to see you with a bus again!
fidysea
Postby fidysea » Tue Sep 08, 2015 8:35 am
Wren wrote:Good looking Bus! Good to see you with a bus again!
Thanks Wren!!!
I hope I can get this one going this time. [-o<
I found out that there are some snapped off cover bolts. :-k
I guess That's why this mug aint got no springplate. ](*,) #-o
fidysea
Postby fidysea » Tue Sep 08, 2015 8:43 am
Good news!
The Datsun clutch slave cylinder was out of fluid.
Filled, pumped and shifting now!
The City is bad here about "tagging" unregistered cars for removal.
So I wrapped up the bus in a huge tarp. I really don't want to deal with that mess. I don't have anywhere else to move it. (not that it can roll anyway)
Postby cookiemonster131 » Tue Sep 08, 2015 12:17 pm
great news on the Datsun!
Postby Pat K » Tue Sep 08, 2015 12:31 pm
On its way today. You should be rolling soon... Smile
fidysea
Postby fidysea » Wed Sep 09, 2015 4:49 am
YES!!!
Thanks guys! I will put it to use.
Hope those broken bolts arnt too stubborn to remove.
Postby john jones » Wed Sep 09, 2015 5:35 am
if your 4, 12MM bolts that go through the spring plate into the reduc are broke... good fucking luck..... #-o #-o #-o #-o #-o #-o
Postby Slow Steve » Wed Sep 09, 2015 6:16 pm
Hey Matt... sorry about those broken bolts.. :-" ... How about we build a small dolly that bolts to the frame horns so it can roll around. If you're going to keep it on soft ground you will need to get tires with air, as opposed to the hard ones. Let me know.
sixfootdan
Postby sixfootdan » Wed Sep 09, 2015 9:59 pm
Slow Steve wrote:Hey Matt... sorry about those broken bolts.. :-" ... How about we build a small dolly that bolts to the frame horns so it can roll around. If you're going to keep it on soft ground you will need to get tires with air, as opposed to the hard ones. Let me know.
I have one I can mail you and you can mail it back someday when the looser is rolling.
fidysea
Postby fidysea » Fri Sep 11, 2015 7:07 am
mmmmmm....
a dolly :-k :-k :-k :-k
I am not sure what to do. I was thinking narrow the torsion housing. if the bolts are broken off in it that might help to get them out if the end casting is off.
I am still not sure what direction to go. Stock rgb, narrowed swing, offset plates, or bug IRS. :-k :-k
Bug IRS trans are so easy to come by. Way easier to hit the trans lottery if you have more chances to play.
offset plates with swing axel I could go back stock if I wanted to. :-k :-k
Postby john jones » Sun Sep 13, 2015 8:26 pm
ohh... the 10mm bolts going through the cover are broke? Those aren't too bad... You'll probably have that rocker out of your way at some point, it will make it easy enough to get them out.. I suggest you leave your torsion housing stock. if you want Irs, buy a kit.. save your dough and buy the right stuff.. Wink But... I would NOT even think about that kind of stuff at the moment.. You need to make it solid first thing. Smile Smile Smile Smile Smile Smile Smile if you need to move it. Hire a tow truck flat bed guy to move it for ya...
You need some metal...
Air Kooled Junk
Postby Air Kooled Junk » Sun Sep 13, 2015 11:27 pm
Congratulations on your new bus!! Looks like a great bus to fix.
MichaelDF
Postby MichaelDF » Mon Sep 14, 2015 9:16 am
Yeah, Matt is back in a bus. Glad to see that transition.
Now get that welder out before winter sets in.
-Michael-
DUBFAB
fidysea
Postby fidysea » Mon Sep 14, 2015 11:17 am
Air Kooled Junk wrote:Congratulations on your new bus!! Looks like a great bus to fix.
MichaelDF wrote:Yeah, Matt is back in a bus. Glad to see that transition.
Thanks guys!!!!
I don't have a lot of time with 2 jobs but I am going to do what I can.
Users browsing this forum: Google [Bot] and 3 guests
