Bret's 65 #2 Build Thread
Re: Bret's 65 #2 Build Thread
Postby GTV » Fri May 06, 2016 8:14 am
I've seen quite a few cut, narrowed, sleeved, and welded. An old friend/roommate of mine had one 15 years ago. It seemed to work but I'm sure they do not behave 100% as they were designed to.
I would try a narrowed stock bar first. With the 5" shorter spring packs you are already increasing stiffness, a 3/4" bar will make it rock solid. A stock bar will allow the suspension to move but still keep the front end from rolling around.
Matt Faulkner
Postby Matt Faulkner » Fri May 06, 2016 9:02 am
Franz wrote:How about a coil-over conversion on the front? Use both sets of torsion springs as sway bars with a floating center block?
I was thinking about that one too!
KCW Internship Graduate #1
Postby Bret » Fri May 06, 2016 4:08 pm
Found a solution.
Called and talked to Brian at Sway-A-Way. I have chatted with him a handful of times before. They make sway bars for VW's, but their website is down and does not really have information of what they make for VW's currently.
Well they make runs of sway bars every 4-5 months. I asked Brian if they could make a narrowed one and he said, "Sure....just a matter of changing a few settings on the bender as we make 'em. The bends stay the same, just making the middle length different. If you need it next week it will probably cost you $3-400, but if you're willing to wait about 5-6 weeks and buy it when we are making the next run.....probably run you $125-150."
Done. Screw cutting/sleeving/fucking up a sway bar. I will just wait until its ready.
And just for reference, if anyone out there wants to buy a narrowed VW sway bar over 2".......you can call and talk to Brian.
Postby GTV » Fri May 06, 2016 4:51 pm
That's good to know! I wonder if they would make a smaller diameter bar. I am not a fan of the 3/4" bar at all.
Postby Bret » Fri May 06, 2016 7:24 pm
No clue. Might be worth calling and asking. Tell him I sent you.
I know they make 3/4" and 7/8", but you might find they make different sizes. Never hurts to ask.
Matt Faulkner
Postby Matt Faulkner » Sat May 07, 2016 7:11 am
Great info Bret! \:D/
Postby 63single » Sun May 08, 2016 4:03 pm
Brett,
What about addco?
Postby Bret » Sun May 08, 2016 8:21 pm
63single wrote:Brett,
What about addco?
Hey Aran,
Never heard of Addco. Local? Tell me more.
Postby 63single » Mon May 09, 2016 7:52 am
They are in socal and they do custom sway bars.
Postby Bret » Mon May 09, 2016 7:57 am
I'll have to look them up.
Postby 63single » Mon May 09, 2016 7:59 am
My bad, they are on the east coast. If you look in the faq section on their page they make custom sway bars.
Postby Bret » Mon May 09, 2016 8:29 am
Yeah, looks like they are in South Carolina. No worries. I will still give em a ring.
On another note, this question goes out to anyone and everyone. Engine tarboards. You guys install them on all of your cars? Was changing the engine seals yesterday and my back tarboard is crumbling so I yanked it out and cleaned the firewall of all the old glue residue.
I know it quiets down the engine noise, but what difference does it make compared to if you were just to put a dynamat type deadener on the inside under the carpet?
Would love to hear the KCW assembly crews input on the matter.
Thanks y'all!
Postby GTV » Mon May 09, 2016 11:30 am
I love how a painted firewall looks but that insulation (on both sides) really helps quiet things down. The last car I built I only insulated the cabin side (dynomat and jute) and it's still loud as hell. Could be the IDA's though! Anyway, next time I get the chance I'm going to insulate the engine side, upholstered in a Porsche 356 fashion.
Postby Bret » Mon May 09, 2016 12:47 pm
Thanks for the input!
I will get one ordered now. I know there are two different tarboards you are seeing these days. The OG style from Wolfsburg West (which looks like what KCW is using on builds) and then there is the offering that West Coast Metric is using with is more of a checkered design.
Jered's daughters ragtop:
The WCM product:
Not gonna lie.....I think the checkered look actually looks kinda rad behind a motor. Doesnt come close to the Porsche style upholstered backing though.
Postby Critter1 » Sat May 14, 2016 5:26 pm
How'd the firewall come out? Two weeks to BugO... gonna try to make it with the car?
Users browsing this forum: No registered users and 6 guests
