George's Hotrods
JiI
Re: George's Hotrods
Postby JiI » Fri Jan 27, 2017 11:39 am
Just looked those tires up. 31" diameter in the rear? Wow, that'll play with the gearing! Smile
Jeff
Yeah, like I have any clue what I'm doing....
Postby George » Fri Jan 27, 2017 2:01 pm
JiI wrote:Just looked those tires up. 31" diameter in the rear? Wow, that'll play with the gearing! Smile
Jeff
I don't think it will be a problem with the 2.2 subi motor she's just going to have long legs.
Postby BBWB » Sat Jan 28, 2017 8:18 am
Ya, my bus would do 75mph in third gear easy at 32-3300rpm with my 30" tires. Fourth loped along at 2000rpms@75mph. I've since come down to 27" tires, it's right on 75mph@3200rpm. It was like having a really tall overdrive with the taller tires.
Postby George » Sat Jan 28, 2017 9:03 am
BBWB wrote:Ya, my bus would do 75mph in third gear easy at 32-3300rpm with my 30" tires. Fourth loped along at 2000rpms@75mph. I've since come down to 27" tires, it's right on 75mph@3200rpm. It was like having a really tall overdrive with the taller tires.
Considering the weight ratio to hp this should be interesting. Nice thing about a VW trans is the ability to manipulate the gearing. Wink for now it's looking like a salt flat racer.
Postby BBWB » Sat Jan 28, 2017 10:21 am
^^^That could be interesting, and fun!
JiI
Postby JiI » Sun Jan 29, 2017 10:23 pm
Are you going to put roll up windows in it? If so, how are you intending on making them work at the top?
Jeff
JiI
Postby JiI » Sun Jan 29, 2017 10:24 pm
Jeff
I'll be running a 2.5 subie but it will be all wheel drive. Wink
Jeff
Postby George » Tue Mar 07, 2017 3:37 pm
Ok found and purchased one 1973 running driving Baja bug
Postby alykat » Tue Mar 07, 2017 4:45 pm
Damn George ! I was looking at that a while back thinking if it could be negotiated down a bit it would be a reasonable project. I believe that this should go in the "George scores" coulumn. \:D/
Postby K Leake » Tue Mar 07, 2017 5:00 pm
=D> =D> =D> =D> =D> =D> =D> =D> =D> =D> scored
Postby George » Tue Mar 07, 2017 5:09 pm
THis is definitely a score new brakes axles interior seats runs great shifts great no no rust super clean pan decromed one piece windows just drive to the gas station came home does great. We couldn't get it to start so i offered 1500.00 they wanted 1800.00 they said ok so John and I hooked up the tow bar towed to KCW got out was going to show Matt how she turns over hit the key and she fired up runs great sounds great. It's a turn key Wink
21views
Postby 21views » Tue Mar 07, 2017 6:16 pm
George wrote:THis is definitely a score new brakes axles interior seats runs great shifts great no no rust super clean pan decromed one piece windows just drive to the gas station came home does great. We couldn't get it to start so i offered 1500.00 they wanted 1800.00 they said ok so John and I hooked up the tow bar towed to KCW got out was going to show Matt how she turns over hit the key and she fired up runs great sounds great. It's a turn key Wink
\:D/ \:D/ \:D/ Score!!!
Postby way2cool » Tue Mar 07, 2017 8:03 pm
Retail George?...no tradin'!
Now this is definitely a great score...should be lotsa fun out 'n' about in the wilds of Colorado
Postby JWDII » Wed Mar 08, 2017 5:06 am
Nice, George! Now it needs a roof rack with a permanent rod tube. I had a black 71 Baja for a while. It was a great jump out vehicle. I kept a rod with me all the time, pull over , jump out and fish! Those were some fun times.
Postby George » Wed Mar 08, 2017 6:11 am
JWDII wrote:Nice, George! Now it needs a roof rack with a permanent rod tube. I had a black 71 Baja for a while. It was a great jump out vehicle. I kept a rod with me all the time, pull over , jump out and fish! Those were some fun times.
Thank you, that's my plan put a rod and some tackle in and go!!
