Eriks 1958 356A
Re: Eriks 1958 356A
Postby Franz » Thu Jun 25, 2015 6:28 am
Hey Erik, I was working on the regulator ...trying to get the light to stay out. I thought it was the adjustment on the closing solenoid of the old Mercedes Bosch regulator. After several adjustments, and intermittent operation. I swapped the regulator to a new transistor unit to test.
New regulator, same symptom. Light is on until about 2500rpm. I think the issue is a weak generator. Full field test confirms.
Maybe we should change it out before it leaves? At least, get a spare located, so that you have the replacement ready to go.
The generator is small diameter 12volt (6 volt diameter) that would have originally came on a 66-67 Porsche 912
Re: Eriks 1958 356A
Postby Franz » Thu Jun 25, 2015 7:30 am
I replaced some hub cap clips and painted the original 2/59 wheel yesterday. Going to get a spare tire mounted too.
Erik.
Re: Eriks 1958 356A
Postby Erik. » Thu Jun 25, 2015 9:12 am
Franz,
If you are able to switch the generator before the car is picked up that would be the best for me. Will save me from pulling the engine as the first thing I do! If not - I do have a spare myself. A lot of the Vw and Porsche industrial engines with these small diameter 12V generators in Norway. We have 4-5 of them in our small workshop in Bergen.
Very nice wheel!
Erik
Re: Eriks 1958 356A
Postby Franz » Thu Jun 25, 2015 9:56 am
No need to pull the engine. The design of the generator stand allows it to be pulled out of the front. Should be an easy job.
The truck driver just called and said he would be here 6pm. ](*,)
Erik.
Re: Eriks 1958 356A
Postby Erik. » Thu Jun 25, 2015 12:37 pm
Oki!
Erik
Re: Eriks 1958 356A
Postby Franz » Thu Jun 25, 2015 1:05 pm
The soonest that I could have the part would be tomorrow. Truck is scheduled to be here tonight. And they were very expensive. $550
It works well enough for shipping.
I wish I would have driven it more before you were here ](*,)
Re: Eriks 1958 356A
Postby Franz » Thu Jun 25, 2015 1:13 pm
Packed and ready to go.
Erik.
Re: Eriks 1958 356A
Postby Erik. » Thu Jun 25, 2015 2:25 pm
No worry!
Nice evening job to switch it then!
Erik
Re: Eriks 1958 356A
Postby GTV » Thu Jun 25, 2015 3:49 pm
Franz wrote:Image
I'm happy that worked out!
Re: Eriks 1958 356A
Postby Pat K » Thu Jun 25, 2015 5:52 pm
Erik. wrote:No worry!
=D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> ....I've heard .. :-k :-k .. that once it leaves here the hard stuff is done... Smile Smile
Re: Eriks 1958 356A
Postby Franz » Fri Jun 26, 2015 7:02 pm
Loaded and ready to go. The transport guy was late. Safe travels friend.
Erik.
Re: Eriks 1958 356A
Postby Erik. » Mon Jun 29, 2015 8:23 pm
Arrived at Calship, CA
Erik
Re: Eriks 1958 356A
Postby dirie1 » Tue Jun 30, 2015 6:41 am
Damn this thing is such a sweet ride!
Congrats Erik, you have one badass ride
Re: Eriks 1958 356A
Postby john jones » Tue Jun 30, 2015 6:54 am
bye bye bye bye bye!!! =D> =D> =D> =D> =D> =D> =D> =D> =D>
My favorite projects.. Completed one's!!!!!!!!!
Whistlebritches
Re: Eriks 1958 356A
Postby Whistlebritches » Mon Jul 06, 2015 6:11 pm
Amazing!
Users browsing this forum: Bing [Bot] and 4 guests
