Emily's Low Light
Re: Emily's Low Light
Postby scottsain » Thu Oct 29, 2015 4:40 pm
John Schweers buy it?
Postby Franz » Mon May 23, 2016 6:07 pm
Went to California last year. Got some miles. Something happened. Engine locked. Most likely oil starvation. I will see tomorrow when I take the bottom end apart.
Postby jb » Mon May 23, 2016 6:43 pm
That no fun [-X Can't remember did you put check valves in those long ass oil lines up to the coolers?
Postby Franz » Mon May 23, 2016 7:10 pm
No check valve. The coolers are pretty low. Below the bumper. I didn't think drain-back would be an issue.
Postby rustabus » Mon May 23, 2016 7:12 pm
Damn! These fucking big engines!!?? ](*,) ](*,) ](*,)
Postby PeteSC » Tue May 24, 2016 6:12 am
That rear bumper though.... =P~
Hate the motor troubles for the new owner, but love seeing this thread pop back up. You guys crushed this build.
Postby john jones » Tue May 24, 2016 7:07 am
IMO.... this is probably a technicality of those dual coolers and 30 feet of line required to get the oil to the front and back to the back... start up, if not done correctly.. could be a bitch on this motors bearings.. #-o #-o #-o #-o #-o #-o #-o #-o #-o
Postby dirie1 » Tue May 24, 2016 9:09 am
AH DAMN!
Such a cool ride! Its in good hands now
Postby andym » Wed May 25, 2016 6:25 am
This is a badass car,
Postby Franz » Wed May 25, 2016 6:45 am
The carnage. The rear main was the one that locked. Spun the pin in the case. Not terrible. May be able to save the case.
The oil pump had some deep scratches too. Like someting went through it?
One lifter shelled out. The other 7 looked great. The cam looked and measure good. But I don't know about re-using it.
It had a Kennedy clutch. The early throw-out bearing conversion piece came apart.
Boxed and ready to go the the machine shop. AKA Painter's Grinding.
Postby andym » Thu May 26, 2016 10:04 pm
So you think this bad bitch was being hot rodded? Or just shit happens?
Postby Franz » Mon Jul 04, 2016 5:16 pm
Decided to spend my 4th working. Kind of boring I know. Planning to grill and light fireworks this evening. Next year will be better I promise.
We got the long block back from Painter's for this ghia. They had to do a little machine work on the case. The rear main bearing locked to the crank.
I started putting it back together today. Making small changes.
The clutch was blown-up too.
Ditching the Jaycee pressure relief oil system for strait simple full-flow with a check valve. Maybe a thermostat would be a good idea too? To shorten the oil system loop when its cold. But I worry about it sticking closed, not allowing the oil to the coolers. That could cause a catastrophic failure. Trade offs. :-k
The rear main bearing. The case was damaged. Painter's was able to machine it for a stepped pin.
Postby john jones » Tue Jul 05, 2016 7:14 am
she's in.
Postby john jones » Tue Jul 05, 2016 7:15 am
Look at that tuxedo!
21views
Postby 21views » Tue Jul 05, 2016 9:31 am
john jones wrote:Look at that tuxedo!
Tuxedo :-" :-" :-" that is some classy shit =D> =D> =D>
Users browsing this forum: Baidu [Spider] and 6 guests
