Door Mechanism Info
//Door Mechanism Info
Door Mechanism Info2018-04-12T08:24:16+00:00
Home Forums Technical Questions Door Mechanism Info
Viewing 9 posts - 1 through 9 (of 9 total)
  • Douglas E Fresh
    Does a good tutorial thread exist for rebuilding the door mechanisms?  I have not been able to find a thread dedicated to it or seen it buried in a build thread.  Any help would be appreciated.   I have put this job off for long enough because I have heard its quite a pain in the ass.
    Not that I know of.
    What door you working on? Front bus doors are easy. Cargo doors are not. Most likely they will need some tig welding on the cam inside the mech.
    Douglas E Fresh
    Im working on the front doors Franz.  Im going to bring my bus up in a few weeks and I wanted fully operational doors.
    soak/clean with solvent. lube with spray lithium grease.
    Sometimes the mounting flange breaks loose. Easy to weld the steel back together.
    Douglas E Fresh
    Good Stuff.  Thanks Franz.  Was Planning on taking 4/20 off and bringing my bus in.  Are you going to be available that weekend?
    Weekend no. Friday kind of. Rusty probably has me scheduled to work on blue thunder.
    What do you need? Carb tune?
    Douglas E Fresh
    Yeah pretty much.  Normal maintenance.  I wasn’t able to make it in last year because I was so tied up with new house so its in need of a little lovin.  I was taking the day off as well and could help with some things as well.
    I don’t know exactly how busy I’ll be on Friday. But I am sure I can find time to help. Bring it down.
    Douglas E Fresh
    Great Franz..I appreciate it.
